Page 3 of 3
Re: RB200 kit, yay or nay....
Posted: Tue Oct 04, 2011 11:34 am
by sydduckett
apart from the addition of an augusto my rb20 is a standard set up with a 30m delly and franspeed race pipe. JB dynoed it and it came out at 19.5 brake whcih i was pleased with, especially as Johns Dyno tends to turn out to the lowest figures for scoot dynos (that is unless you used the one at mesrea, just ask Mark... :D )
Posted: Fri Oct 07, 2011 4:02 pm
by Eibar
We get just shy of 28brake on our tuned RB sprinter, suspect piston is a little fooked now, but new piston and possible further tuning on the way. As a matter of interest whats the max bhp/torque anyone has got from this kit?
Posted: Fri Oct 07, 2011 5:28 pm
by jaymarriott
Heck, that some power....
I've got my hands on a Stuart Owen built 230cc motor now ;)
So I guess the RB is for sale once I've give it a once over.
Posted: Mon Oct 31, 2011 1:40 pm
by Spaceman
jaymarriott wrote:I was going to go for a racetour piston, in which I can keep my crank as it is and get a new downpipe made for my Avanti. MMM sound fun.
Would I need to cut a hole in my side panel?
I had to cut a hole in my GP side panel for a 32mm Mikuni. There seemed to be enough clearance when you looked in from the flywheel side with the RH side panel on, but when I had it dynoed at Chiselspeed we found that fitting the side panel took 5bhp off the max reading and made the curve shape rubbish. There is a shorter manifold available (worb5 I think) but it costs over £100 :shock:
Posted: Mon Oct 31, 2011 1:50 pm
by Spaceman
I forgot to say, I love the RB20kit, after my dyno visit to Chiselspeed it's making 20.5bhp with a very wide spread, over 2000revs above 18bhp, good torque too with the CS road/race exhaust, takes off when it hits the power band, gains revs really quickly. I've done about 1500miles since I got it with no problems attributable to the actual kit, I think it's a good option for the readily available small block casing.
Saying that, the minute it turns really cold it's getting taken to bits and tuned! I'd like around 25bhp ideally, just for a bit more fun without making it too fragile, should be easy enough to achieve.
Posted: Mon Oct 31, 2011 4:02 pm
by willwander
Eibar wrote:... As a matter of interest whats the max bhp/torque anyone has got from this kit?
No idea. But Chiselspeed's "Fat Lass" makes 30+bhp, no welding, no extra ports, standard fan, cowls etc.
