Page 3 of 3
Re: Cylinder Damage
Posted: Tue May 31, 2011 10:46 pm
by Danger
bilko could you just not stick another topend on it rejet carb to suit an not worry about all that lc stuff till the winter leaving it on for show sort of thing just a thought m8
Re: Cylinder Damage
Posted: Wed Jun 01, 2011 8:06 am
by Bilko
No mate.
Spigot size is different so the crank case mouth is reamed out, no air cooling and I think the crank size all means that's not possible.
Re: Cylinder Damage
Posted: Wed Jun 01, 2011 5:22 pm
by Danger
oh rite ok m8 , i take your other motors are in bit to then
Re: Cylinder Damage
Posted: Wed Jun 01, 2011 6:12 pm
by Bilko
Yes, 4 engines, all in bits and needing parts to rebuild.
Re: Cylinder Damage
Posted: Wed Jun 01, 2011 7:03 pm
by Dazza
What have you to lose by cleaning the barrel and piston up and using it?
You may spend money on a new piston and replate and find another as yet unknown problem may cause more damage.
That piston looks fine, a good clean up, bit of cross hatching with a junior hacksaw to retain oil and go for it matey..a cheap fix at least till the rest of the setup has proved itself then for piece of mind get it replated over the winter..
Re: Cylinder Damage
Posted: Wed Jun 01, 2011 10:16 pm
by Bilko
Hello Dazza,
Thanks for the input mate. If I had everyone telling me it wasn't going to be a problem or it was just for me on the Lambretta, I'd have maybe gone for it,but with seize marks on all four parts of the barrel where the studs are and the fact my significant other is on the back and I don't want her stuck in the @rseh@le of nowhere because I didn't do a good job of cleaning up a seize.
Last time I tried cleaning up a job like this I made a right balls up.
As I say, thanks for all your help though. That goes to everyone.
