Page 3 of 3
Re: RB Cylinder repair
Posted: Mon May 30, 2011 9:43 am
by turbovan
aptec best place harry had some done nice finish plus ported at the same time.
Posted: Mon May 30, 2011 9:46 am
by turbovan
aptec seem some work done on ts1 barrel harry had done.ported at the same time
Posted: Tue May 31, 2011 12:19 pm
by voicey
Well gents, thank you for all the replies. Here's an update of what I'm doing.
The barrel and head are being sent to Harry Barlow, the Nikasil will be removed and replaced with Ceramic, the ports will also have some work done as some of the original porting design is slightly flawed. A new modified piston/rings supplied by Harry and then I get the joy of running it all in again.....
He tells me the ceramic barrels are almost bomb-proof, so here's hoping it runs a bit longer than the original set-up. He seems a very straight-up bloke too, so I've every confidence.
Not cheap, but when ever is running a Lambretta cheap?....
Posted: Tue May 31, 2011 12:29 pm
by lozmondo
mark wrote:any chance you can explain the benefits and pitfalls please , i have heard of both both not had it explained in common english . im sure others are interested as well
Apticote 2000 is the one I have used previously
Have a look here
http://www.poeton.co.uk/w1/nickel-silic ... oating.htm.
I have had several ceramic barrels and never had a problem related to bore.
Posted: Tue May 31, 2011 7:55 pm
by Diablo
lozmondo wrote:mark wrote:any chance you can explain the benefits and pitfalls please , i have heard of both both not had it explained in common english . im sure others are interested as well
Have a look here
I've never had a problem related to being boring.
I beg to differ
Posted: Tue May 31, 2011 9:36 pm
by lozmondo
