Re: why do people still want ts1s ?
Posted: Wed Mar 11, 2009 5:56 pm
well i just rode dryballs scoot. its not as powerfull as mine but has more grunt. mine hits the poer and goes quite agressivly but dryballs scoot is much smoother, more forgiving through the gears and does not dropp out of the power like mine does.
my kickstart will hold my 15 stone as my compression is so high.
with less space behind the panel his 30mm carb runs cleaner and crisper where as mine rours.
so im back with the ts1
but will be going with a 30mm mikuni, a low comp head, 60mm alpha crank and race tour piston. it will need to pull li150 17/46
i may need to return to using twin tanks so i can get a filter between them too.
glad i didnt order the rapido
....glad they never answer the phone now
