Page 3 of 3
Re: squish too big = non runner?
Posted: Sun Sep 12, 2010 7:45 pm
by lambrettasam
rocho68 wrote:with the head off , move piston to bottom dead centre and see if the top of the piston is level with the bottom of the transfers , u will need to take carb manifold off to check the inlet timing and the same with a mirror on the exhaust to check that theres no problem with these
So i did this and this is what i got:
inlet: 145
exhaust: 181
transfers 84
do those figures mean anything to you?
thanks
Posted: Sun Sep 12, 2010 11:13 pm
by J1MS
Transfers 84 ?
Re: squish too big = non runner? - ports heights
Posted: Mon Sep 13, 2010 8:44 am
by lambrettasam
hmmm, that doesn't sounds healthy... Problem is i don't understand those figures, is there any way to learn more about what standard figures should look like and how to adjust?
Since i think this engine won't be running as it is, I took the barrel off and started to strip it down. It will be undergoing a full rebuild this winter. (new seals, clutch, bearings... everything replaced by uprated materials to cope with a bigger engine)
