Page 3 of 3
Re: variatronic
Posted: Fri Aug 13, 2010 9:46 pm
by tea5ive
firekdp wrote:tea5ive wrote: i too need to know how to line the boss up (key way) to right place for the trigger as joe said there is no trigger on the flywheel . i know that they fire twice at 180 degree intervals so it wont mater which firing point you use. its just finding it with out moving the boss round a bit at a time.
I thought that due to the layout of the rivets on it that the boss will only fit in two positions.
Due to the stator/flywheel having no pick up system, either of these two positions will be correct.
i have just had a look at the flywheel, and yes as you said it only fits two ways there is two gaps or two bigger than the others between the rivets these are at 180deg to each other. cheers smon
Re: variatronic
Posted: Fri Aug 13, 2010 9:55 pm
by tea5ive
joespeed wrote:firekdp wrote:tea5ive wrote: i too need to know how to line the boss up (key way) to right place for the trigger as joe said there is no trigger on the flywheel . i know that they fire twice at 180 degree intervals so it wont mater which firing point you use. its just finding it with out moving the boss round a bit at a time.
a nice man from cambridge lambretta gave me a short cut to reassembling the boss to the fan ,when the tdc arrow is at twelve o clock the keyway is at about seven o clock ,he then said in needs to be 'charlieized',oh whats that i asked ,two nice tig welds just to make it 'belt and braces' and if charlie cant shake it off with close to forty horses then your little ts should be ok,
regards
joe
joe, once the vegatronic flywheel is re bossed and then tried i will tig weld it up just to be on the safe side, with all the extra power you cant take any chances :shocking:
. cheers simon
Re: variatronic
Posted: Mon Aug 16, 2010 8:46 pm
by joespeed
still not sure whether the varitronic is the way to go!
got the flywheel bolted and tigged up ,fitted new coil pack ,assembled as it came out,tried to start it ,it took three prods and kicked back forth kick sprung into life ,only to find i had four reverse gears,engine is running in the opposit diection!
what have i done wrong?
regards
joe
Re: variatronic
Posted: Mon Aug 16, 2010 8:53 pm
by wack 63
It is firing too advanced so retard (clockwise) the stator, then check with a strobe. I set mine at 25 degrees fast idle. Or if the stator is in the original position have you got the boss right?
Re: variatronic
Posted: Tue Aug 31, 2010 10:50 pm
by joespeed
well i'm getting there but very slowly.i have two timing guns(cheap crap) and a super snap on but none of them will function with this varitronic,can you recommend one?
regards
joe
Re: variatronic
Posted: Tue Aug 31, 2010 11:19 pm
by Wayne Miller
joespeed wrote:well i'm getting there but very slowly.i have two timing guns(cheap crap) and a super snap on but none of them will function with this varitronic,can you recommend one?
regards
joe
Camlam do a timing gun for the varitronic
Theres a link to it
here
