Page 3 of 3
Re: LTH Europa 225 kit.
Posted: Tue Jul 20, 2010 11:37 pm
by ArKaTxU
adriang wrote:
Rapido 225cc. Carbs are either PHBH 30mm or PWK 28mm (Genuine round mouth, not the OK 30-28 oval).
I only use Silkoline at 4%.
Running in.. took it easy for about 500ks, was running like a dream, then heat seized two up at about 100kmph on the motorway and it was about 35 degrees! . Inspection showed the clearances were way too tight. Barrel was matched to the new piston, seems right as rain now, had a pretty hard run, two up for about 150k's p the motorway and it didn't miss a beat. Drank fuel though, the motivation for a LTH reed kit.
OK, thanks for the info
Posted: Wed Jul 21, 2010 5:55 pm
by Supereibar
RB20 not working well for you mate? Whats the deal? Too much Patxarán before riding? Joking aside, where are you thinking of fitting this new 225 piece of kit? You will need a bigger engine block.
Posted: Wed Jul 21, 2010 8:40 pm
by ArKaTxU
Supereibar wrote:RB20 not working well for you mate? Whats the deal? Too much Patxarán before riding? Joking aside, where are you thinking of fitting this new 225 piece of kit? You will need a bigger engine block.
Hi Jamie!
My RB20 still pull like a train, and I am thinking in my return to the jet200 and his "boring" (compared to RB20) stage4 running in and I am watching options
Viva el Patxaran!
