Page 3 of 3
Re: knocking noise on scoot rs anti dive
Posted: Fri May 14, 2010 4:53 pm
by honestbob
have you checked that the disc does not catch the link bar under compression on the LTH hub ?
a mate of mine had his disc ryubbing on the bar if he braked whilst going around a corner. he had to take the link bar off and use it without anti dive.
Posted: Fri May 14, 2010 5:02 pm
by soulsurfer
honestbob wrote:have you checked that the disc does not catch the link bar under compression on the LTH hub ?
It's not an LTH hub, made by the same people but they use a cheap Taiwanese caliper and a smaller disc on the LTH, the position of caliper and disc would be different to this.
Posted: Tue May 18, 2010 6:32 am
by honestbob
If the disc is bigger the disc will touch more easily when you corner the pressure on one side of suspensionis more than uther wheel moves over toward fork leg and will tuch link bar i would checkit
Posted: Tue May 18, 2010 9:20 am
by soulsurfer
honestbob wrote:If the disc is bigger the disc will touch more easily when you corner the pressure on one side of suspensionis more than uther wheel moves over toward fork leg and will tuch link bar i would checkit
I did a quick mock up to check the distance, there seems to be plenty of room. I can only assume the disc sits closer to the hub than your mate's LTH, as I say, this one isn't the same as the LTH.
Posted: Sun Feb 13, 2011 9:25 pm
by joespeed
soulsurfer wrote:Image
this looks the dogs !who makes it? and how much?
the scootrs one looks cheap and cheerful but could it be bettered cheaply!
