Page 20 of 21
Re: FOXHAT 260's
Posted: Tue Feb 14, 2012 6:31 pm
by niz
Rang and spoke to Alan today, planning on getting the RB260 monster built by them. They were very helpful over the phone, gave me some great advice. ;) Will let you no how it goes.
Re: FOXHAT 260's
Posted: Fri Feb 17, 2012 10:42 am
by tj hooker
dont standard rb250s produce that much power ?. my friends rb225 with just matched casings did 26bhp at diablos
Re: FOXHAT 260's
Posted: Fri Feb 17, 2012 12:44 pm
by TS1-200
We all know that you can`t compare power outputs from different dyno`s. Also I spoke to Arthur at length last year while he was giving me a lift to Calais from Amiens after my scoot spat its plug out and stripped the thread, never met him before that, full time he is a motor technician I believe, but his knowledge of Lambretta engines and the tuning of them is mind blowing, most of which went straight over my head ! We were in a van following his son and his mate both riding Lammies with big TS1`s and we couldn`t keep up with them, only when they stopped for a break or fuel.
Re: FOXHAT 260's
Posted: Fri Feb 17, 2012 8:08 pm
by tj hooker
seems like a lot of work and expense to end up with same bhp as bolting the standard kit on
Re: FOXHAT 260's
Posted: Sat Feb 18, 2012 3:15 am
by corrado
Which standard kit does 85 in 3rd gear?
Re: FOXHAT 260's
Posted: Sat Feb 18, 2012 9:10 am
by Special X
Any sccoter on TV200 gearing with an engine that revs to 9,600rpm. Conversely it won't pull in third from less tham 48/50 mph. It's geared to do nearly 110mph in top so I reckon it won't pull 4th. With GP200 gears and 19/47 It would pull (possibly acheivable on the road but not sure) 75 mph in third with useful power from 45 mph, and a theoretical 98mph in top. With std GP200 gearing it would do slightly over 70 mph in 3rd and an acheivable 92/93 top speed.
About what a well built RB250 would do I think
Re: FOXHAT 260's
Posted: Sat Feb 18, 2012 10:24 am
by TS1-200
I think all this talk about 85 in 3rd possible 98 in 4th is all academic ,I think anything over 80 on what is basically a 50yr. old commuter bike is fuxxing scary, I do like to ride my TS1 quickly, but at these sort of speeds I tend to think....what if ? I think its all about good acceleration and generally comfortably quick cruising speeds.
Re: Re: FOXHAT 260's
Posted: Sat Feb 18, 2012 10:35 am
by Andy Pickering
TS1-200 wrote:I think all this talk about 85 in 3rd possible 98 in 4th is all academic ,I think anything over 80 on what is basically a 50yr. old commuter bike is fuxxing scary, I do like to ride my TS1 quickly, but at these sort of speeds I tend to think....what if ? I think its all about good acceleration and generally comfortably quick cruising speeds.
I agree 100 %, lammys at high speed sets the brain thinking..:-o
Sent from my GT-I9000 using Tapatalk
Re: FOXHAT 260's
Posted: Sat Feb 18, 2012 10:54 am
by tj hooker
what goods 85mph in 3rd gear. unless this street racer only street races on the m6. sureley its how fast you can get to it which i cant see it being eye popping
Posted: Sat Feb 18, 2012 11:14 am
by willwander
I'll agree with that, full bodied lammy's can go into a s**t yourself speed wobble with the slightest bump or cross wind once your approaching 90, where your weight is on the bike also makes a big difference. There's no way I would ride mine at anywhere near that on the road.
I've tried a few things to try make mine more stable including stiffer rear shock and engine mounts but it is still a problem might have to try a steering damper next. If anyone has any other ideas about improving straight line stability I'd like to hear from you.
