Page 20 of 32
Re: SIP Lambretta Digital Speedo
Posted: Tue Oct 14, 2014 2:11 pm
by Andy W
I have done the same as Minority and I'm sure I used a Oil Level plug as fitted to the chaincase cover, hope that helps.
Posted: Tue Oct 14, 2014 2:20 pm
by Nerdy Norm
Thanks Andy, but the oil level plug is a bolt, right? I think Minority is talking about a spacer nut, or am I missing something?
Posted: Tue Oct 14, 2014 3:36 pm
by Minority
Nerdy Norm wrote:Thanks Andy, but the oil level plug is a bolt, right? I think Minority is talking about a spacer nut, or am I missing something?
Yes it was just an ordinary nut that happened to fit over the axle and was about the right thickness. Unfortunately I have no idea what size it was, I just found one in my box of nuts and bolts that fitted.
Posted: Tue Oct 14, 2014 3:41 pm
by Nerdy Norm
Thanks - and there was me thinking that I'd need a special "MBD CNC-machined stainless speedo drive spacing system"
Posted: Tue Oct 14, 2014 6:45 pm
by Andy W
Ahh I see what he's done now, can't see pics on works computer. I thought he had removed the speedo drive and blanked off the hole the brass piece and worm drive fit into. Sorry about that.
Posted: Tue Oct 14, 2014 6:54 pm
by Nerdy Norm
No problem Andy, always nice to have options.
Posted: Fri Oct 17, 2014 9:28 pm
by victor
So, if I swap to mph it also displays F... Any way to keep C as temperature?
Or do I have to manually reprogram the kmh speed to show mph if I want Celsius?
Posted: Fri Oct 17, 2014 11:26 pm
by Minority
victor wrote:So, if I swap to mph it also displays F... Any way to keep C as temperature?
You have two choices as standard, MPH/F or KPH/C.
If you want MPH/C you will have to mess around with the tyre circumference to fudge it as you suggested.
In theory if you set to KPH/C and divide your tyre circumference by 1.6 (if that's within the allowed range) you should be about right.
Posted: Sat Oct 18, 2014 12:18 am
by victor
That was my thinking to - thanks for confirming!
Posted: Sun Nov 02, 2014 11:19 pm
by kalifornia
I've not been through all of the responses on this thread but I was having problems with my SIP speedo freezing and not starting up properly etc.
It appears that you must run a resistor type spark plug if you are running a battery-less A/C system to make them work correctly. I switched from a B8ES to a BR8ES and it works perfectly now.
Hope this helps.
