Page 19 of 20
Re: Here's a new MBD speedo in Mouses new headset.
Posted: Mon Jan 24, 2011 5:49 pm
by ArKaTxU
Lazarus wrote:working
the link is no longer
Try this one:
http://www.addo-pix.com/lambretta-ts1-service.html
Posted: Mon Feb 07, 2011 5:51 pm
by Lazarus
Thanks very much ArKaTxU just what I was after m8
Posted: Tue Feb 22, 2011 12:41 pm
by PRE0ATS
minotaur wrote: i would like a white/ cream light , like the original set up if this would still work in daylight, i think this would work with most colours, imagine a green light on a red or purple headset? keep it subtle and minimalist this makes it more universal.
In view of the comment above, can anyone confirm if the speedo is still only available with a green backlight?
Whilst the reliability/function of the speedo is the most important thing, I have to admit that I agree with minotaur that a white LCD display would be much more universal - the green light is the one thing making me consider the SIP speedo instead, as the green would look odd with the colour scheme of the project I'm planning.
Posted: Tue Feb 22, 2011 1:08 pm
by Ian Hepworth
PRE0ATS wrote:minotaur wrote: i would like a white/ cream light , like the original set up if this would still work in daylight, i think this would work with most colours, imagine a green light on a red or purple headset? keep it subtle and minimalist this makes it more universal.
Green backlight only at the moment. No plans to change that.
Posted: Thu Feb 24, 2011 11:20 am
by madmaex08
the battery in my speedo died. most likely because of the constant freezing cold this winter and the general lack of use of the speedo. do i need to change the battery (and if how?) or is it going to be revived upon firing up the scoot? i take it i need to set it up from scratch though?!
Posted: Thu Feb 24, 2011 11:40 am
by Ian Hepworth
madmaex08 wrote:the battery in my speedo died. most likely because of the constant freezing cold this winter and the general lack of use of the speedo. do i need to change the battery (and if how?) or is it going to be revived upon firing up the scoot? i take it i need to set it up from scratch though?!
The battery will recharge when you start running the scooter again. I'm not sure if you will have lost your settings.
Posted: Thu Feb 24, 2011 2:11 pm
by madmaex08
thanks for the quick info; will let you know about the settings.
Posted: Fri Apr 01, 2011 2:08 am
by ulyssescale
That link is viable, but the walk-thru for the speedo install is no longer there.
Posted: Tue Jun 14, 2011 9:22 pm
by Train Driver
Did these get sorted in the end or was it another good idea let down by poor suppliers
Posted: Tue Jun 14, 2011 9:46 pm
by paulmgreen
I have had two that both worked fine......
