Page 18 of 20
Re: lambretta 290 rotax
Posted: Thu Dec 20, 2018 11:48 am
by Adam_Winstone
Nice work. I hope that the exhaust valve delivers the sort of delivery that I expect it to, which should really benefit the ride.
Great stuff.
Posted: Wed Jan 23, 2019 9:35 am
by holty
I have made a start on upgrading my rotax to a powervalve model, ive removed the jetski barrel and pleased to see the piston in very good condition and the crank as well, carb size is being increased to 38mm the same size as the skidoo that the barrel came off. I have removed the inlet manifold and welded a bigger tube on it to match the carb and done a test fit to check position, which is good, I also did a leak test by clamping the manifold to a rubber sheet on a steel plate, found a leak and fixed that, just waiting for some base gaskets to arrive, exhaust angle where it leaves the barrel is not the same as the jetski so exhaust will need altering so that's my next job after the barrel is fitted, will add more pics later
ImageUntitled by stephen holt, on Flickr
Posted: Wed Jan 23, 2019 2:38 pm
by garry inglis
looks good steve carb sits well in there looks odd with fuel tap on this side have you got it going out of the choke hole to turn fuel on and piston looks clean thats good jetting mate
Posted: Wed Jan 23, 2019 3:42 pm
by holty
fuel tap just has a penny washer riveted into the slot so panel has to come off to turn it on and off, I just leave it on as a rule, not been a problem upto now, I have no route to get to the fuel rod, cylinder head is in the way, I was quite impressed with the piston condition as well, jetting is down to martin at chiselspeed, it will be going back on his dyno once its up and running and ive got a few miles on it.
Posted: Wed Jan 23, 2019 5:58 pm
by mick1
I fitted an electric valve on mine to overcome this. Works fine unless your battery's flat !
Posted: Tue Feb 05, 2019 10:05 am
by holty
mick1 wrote: ↑Wed Jan 23, 2019 5:58 pm fuel tap just has a penny washer riveted into the slot so panel has to come off to turn it on and off, I just leave it on as a rule, not been a problem upto now, I have no route to get to the fuel rod,
what valve did you use, sounds like a good idea.
Posted: Tue Feb 05, 2019 10:10 am
by holty
fitted my rave cylinder to my scooter at the weekend, had to alter a bit of plumbing, got a bit more to do before I fit some stronger clutch springs
Posted: Tue Feb 05, 2019 6:52 pm
by garry inglis
whats the rubber cap with the spring clip steve is that for coolant
Posted: Wed Feb 06, 2019 4:25 am
by guygrrr
At the expense of stealing Holty’s thunder, his new cylinder uses a vacuum actuated exhaust valve. The black plastic is the cover for the vacuum diaphragm. It’s a neat upgrade and should give his bike more bottom end.
Posted: Mon Feb 18, 2019 3:02 pm
by czeckson
principle looks familar to me:
