Re: my 90SS's
Posted: Sat Nov 19, 2011 10:27 am
Looking for a pilot Oz? Puts hand in the air and shouts me me me me me
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Bloody hell........ I like that one too........ hmm !!?? Anyone wanna swap a small frame for a PushPak project bike ??OzOAP wrote::biggrin:
The 'chequered' shirt goes with something a lot sexier than a Lamebwetta
Hi Tony,tony wrote:![]()
Something about tuned smallframe barrels,you can look at lambtetta stuff all day and get bored,but you could cut that pic out and stick in ur wallet.tony wrote:thanks tony... hope all is ok with you mate.
The exhaust sleeves you spotted were fitted recently.. in fact all four stud holes have the sleeves now as this motor is being rebuilt for a mate.. (this time with a falc case reed conversion... )
I ran it with open studs to get the back wall angle I wanted on the secondaries and to remove the cast lumps on the exhaust side. It was simply sealed with O rings either side of the ports. The top area and bottom is of course seal by the head and packer anyway.. but as its now going to someone else I wanted it more professional.
Balance wise the fella couldnt believe the casings could take the forces. He wanted to improve the crank and balance this way but with the timings I used and how I profiled the crank it was easier to simply fit a small weight to the flywheel at a given point. The plan was eventually to remake the crank and take it back....
This is what it sounded like.. I was testing a mikuni back to back with dellorto at the time
http://s228.photobucket.com/albums/ee11 ... deo005.mp4
The motor below is maybe more interesting...
This is what is fitted to the red 90ss.
Its a case reed (cr125) with a T5 barrel. I built several of these conversions maybe ten years ago now. The first was a rotary with race inlet timing and trans/ex. A close ratio box was fitted to help.
the barrel in that photo is the first barrel I did. Its simply a modded T5 barrel to the above race spec. Quite a lot of attention was paid to the exhaust port area as it bottle necks on this barrel.
The next one was reed and power was 21 or thereabouts on Jb's.
The barrel below was the next one I did. This time its a linered down to 58mm T5 malossi 172 barrel. The reason for this was to get the roof angles the malossi uses. While I was there I made the bridged port because i had never done one before tbh!![]()
I still have that barrel.. but since then 54stroke cranks became available so I have gone for this with a longer rod too... and a new barrel to 60mm is in progress (one day!) and hence the casings have been machined out in readiness for the larger spigot.
This is what the 135 sounded like. the first bit of noise on the video is Jb porting![]()
http://s228.photobucket.com/albums/ee11 ... I_0870.mp4
