Mr Frog. Your idea with the airbox has already been done. There's a bloke on here called Scooter Loopy John who did the exact same thing, and he was pleased with it. I thought it was an interesting idea at the time and it seems like a good way of utilising what little space you have in the toolbox.
fastfrog
Size matters!
I did have a photo of it somewhere. But typically I can't find it now. :roll:
fastfrog
too bad... :P
Size matters!
fastfrog
many thanks ArKaTxU...
I'm doing it bigger with a 50mm diameter/ 80 long tube passing through the AB wall.
I'm thinking of welding a bigger manifold underneath the AB and fitting a larger air bellow. Don't know which one could fit easily....
Size matters!
ScooterLoopyJohn
Main scooter: 1970 GP 195cc A/F s'type
Works well i also opened up the gap between the seat support , but not realy needed.
fastfrog
I see you didn't open up louvres. Could it be interesting?
Size matters!
fastfrog
It seems that you welded a bigger section manifold bolted under the AB. Can you confirm?
Size matters!
fastfrog
exhaust almost completed:
Size matters!
    Users browsing this forum: Ahrefs [Bot] and 12 guests
