Page 14 of 16
Re: Tubeless rims in the UK?
Posted: Fri Apr 01, 2011 5:55 pm
by T5-190
lammer205 wrote:Has anyone tried to fit one of these rims to a lambretta innovations tubeless hub, or if they could, would they offer one up to see the fit ,would like to know if they are in any way compatable.Got a tubeless hub an like the look of the sip rims, cheers lammer205.
Here you go lammer205 and corrado, the rim fits perfect on their hub/backplate. Also the valve stem misses the brake caliper easily.
Posted: Fri Apr 01, 2011 7:31 pm
by sydduckett
soulsurfer wrote:drunkmunkey6969 wrote:Martin, any feedback on those plates i PMd you about?
Nice, put me down for a couple
haha quality..
Posted: Fri Apr 01, 2011 7:32 pm
by soulsurfer
RICSPEED wrote:i think sip have a deal going on with mb so may be available from them .......cue ian..........
Posted: Fri Apr 01, 2011 10:25 pm
by lammer205
Thanks T5-190 for that, was your hub the one made to take tubless rims only? Lammer205.
Posted: Sat Apr 02, 2011 7:45 am
by soulsurfer
T5-190 wrote:
I might be wrong, but doesn't that have the same gap as shown on the standard hubs? How well does the centre plate fit on the other side?
Posted: Sat Apr 02, 2011 7:51 am
by soulsurfer
These are some more pictures of the SIP rim...
They fit like this to Innocenti and pattern rear hubs and Servetta, Innocenti and Stoffi disc brake front hub. Much better, no?
Posted: Sat Apr 02, 2011 9:08 am
by martinr
if i was af id get a proper engineers written report on there rims to settle this one way or the other then publish it on here and lcgb site . because nobody is goting to buy theres anymore now the sip ones are out
Posted: Sat Apr 02, 2011 9:09 am
by T5-190
lammer205 wrote:Thanks T5-190 for that, was your hub the one made to take tubless rims only? Lammer205.
You're right the hub is made to take a Scootrs tubless rim. If you try to fit a normal tubed rim to it there is no cut out to take the back of the wheel nut studs and the wheel would be slightly off centre.
Posted: Sat Apr 02, 2011 9:17 am
by T5-190
The hub/backplate is machined down to take the wheel rim. The wheel rim fits perfect and is perfectly centred.
Also another thought on this, sent with the new rims is a set of special flat washers that are machined to fit in the recess in the rim and the outside of the stud. The rim surely can only be perfectly centred, this and they are held in place with good quality spring washers and specialy made deep wheel nuts.
Posted: Sat Apr 02, 2011 12:30 pm
by thackers
The S.I.P ones get my vote up to now, not that i'm in a position to get any. Do they come in the same 3 finishes?
It seems to me the whole concept of tubeless is safety, i cant see the point in loosing one worry to gain a fresh one
I think we are getting closer to the final product though
