cheers, had 4 day weekend but only got a couple of hours out there, weather was so nice and wanted to spend time with my daughter
brakes are all bled and working, front is feeling great (anti dive doesnt lock it solid, it moves a bit and I like it the way its worked out), rear I think I got calculation wrong somewhere, master cylinder too big, so it works but appears to lack feel, however thats only from testing in the garage, also its new pads and disc so maybe they need time to bed a bit, if it prooves to be horrid on the road then I have an identical master but with smaller piston, that will give more stroke and should equate to bit more feel at the pedal.
plumbing is all done, electric waterpump works a treat, starting to sound like a space ship when you turn the key, powervalve cycles and water pump whirring away
hopefully have last of wiring finished tonight, relays for kill switch, water pump, fan, headlight
plan is that I will have tank and sidepanels back from my mate by end of week, sidepanels arent a worry, tank I need, but I have a test tank I can just test fire the engine with, need to start getting busy with plug chops and try to get the jetting somewhere near right, except I havent a clue LOL
got the choke setup using the original GP choke lever, that was a nice feeling as its just one more bit that helps it look original, got to check for clearance and fit but think I will put a fan bypass switch in the fuel tap hole, so I can bring the fan in manually in case of any problems
oh I forgot to mention I did have a go at that 3M DiNoc carbon effect film stuff, took a little bit of heat and stretching but I was quite pleased with the result.
yes I know the door lock is the wrong side, BUT I got it from ebay for a quid and the hole was made for it to go through this way, some numpty had filed it out, badly LOL
