Re: Vespa Winter Project
Posted: Thu Nov 06, 2014 12:29 pm
[quote="cartmel808"]Exhaust looks good Gary..... I like the vented side panel as well.
Did the GS160 rim help sort your wheel alignment issue?
Yes it looks as if its going to work, I can remove a bit of the engine bolt area on the engine, shimmy the engine bracket over and it should allow me to align the wheels, it may still be about 5mm of line, but that shouldn't cause any problems.
"but i have always had reservations about curlys that they put the exhaust gas in front of the rear wheel with the oil that the gas obviously contains."
I hear what you are saying, but surly the forward motion of the scooter and the backwards motion of the 2T fumes shouldn't hit the tread of the tyre, but i will keep an eye on this.
" tailpipe looks low"
I have still got another 5/10mm of play due to my mock up engine bracket, this should raise the exhaust more.
This project is on going, If these issues become a problem then I will have to look at other solutions. The front disc, will be on the scooter for next spring, still being used daily.
Cheers for all the positive comments, Gary
