Re: Antidive upgrade scootRs brake.
Posted: Fri Apr 30, 2010 8:47 pm
The backplate/speedo drive locate into the link but
aren't they different for disc /drum links?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Not on the antidive...leebeduff wrote:The backplate/speedo drive locate into the link but
No problem Mike!soulsurfer wrote:Not on the antidive...leebeduff wrote:The backplate/speedo drive locate into the link but
The plate doesn't locate, it would spin if it wasn't for the tie bar, that's how Lambretta antidive systems work, and you can see the speedo drive just sits under the link, it doesn't need to locate.
PS. Not sure whose scoot this is, hope the owner doesn't mind (Nigel?)
soulsurfer wrote:Just the anti-dive Mark. Although the Disc brake isn't perfect by any means, it's not bad and good value for money. I just think the antidive is crude and a joke as far as basic engineering goes.
All troops use bergens I just thought that type were Danish etc more to the point why are Rucksacks called Rucksacks ?sydduckett wrote:Why do the SAS called there rucksacks bergens?....
Wiki: "from the manufacturer's name Bergens, used for a backpack supported by an external frame, usually associated with the British Armed Forces"sydduckett wrote:Why do the SAS called there rucksacks bergens?....
Yes Frank, the idea of the bushes isn't correct for these as there will be sideways movement that needs to be considered. A lot of the movement on these antidive systems is small but it needs to be taken into account as it will affect the handling of the scooter, particularly if braking and turning at the same time.red ghost wrote:soulsurfer wrote:Just the anti-dive Mark. Although the Disc brake isn't perfect by any means, it's not bad and good value for money. I just think the antidive is crude and a joke as far as basic engineering goes.
Is it the way the pivot points are done that you don't like, with the stepped washer things?
So would you say with rose joints,bearings or bushes it would be an ok kit?
frank
