Rb20 head gasket
sydduckett wrote:Is there any where where you can get the correct squishes for specific kits? In my case an RB20. Im guessing it doesnt matter where you have the gaskets as long as the squish is correct. Could I do away with my head gasket by adding a thicker base gasket?
Ta
I run my stage 4 with double base and no head gasket with 1.2 squish but did use sealent on the top of the barrel...head was also tidied up by Sean..just re torqued the head after a few heat cycles..and it did need it...
