Rapido225 clubman to JL3
soosh
Dont think you will get it to go any faster.
goldeneye
had a look at mine for ya. its AV264/x7 needle, top notch. 40 slide, 70 choke jet, 50 pilot, 125 main, remote filter, mixture two turns out. pulls great , clean all through the range, starts first kick with a little choke from cold, then no choke when warm, 42mm clubman.rapido classics are torquey , try a bigger front sprocket , that"ll give you the extra few mph you need. lads round here are running 4.6 , and even 4.4 gearing, they get faster than 65mph, and do loadsa miles on rapidos. ive rode a few, but the first time ive had one on my own scooter, so quite looking forward to using it this year.its getting about 75 miles to a standard tank at mainly full belt, so not as juicy as i was expecting.
mikeallen
Xbox live gamer tag: junkyevenflow69
goldeneye wrote:had a look at mine for ya. its AV264/x7 needle, top notch. 40 slide, 70 choke jet, 50 pilot, 125 main, remote filter, mixture two turns out. pulls great , clean all through the range, starts first kick with a little choke from cold, then no choke when warm, 42mm clubman.rapido classics are torquey , try a bigger front sprocket , that"ll give you the extra few mph you need. lads round here are running 4.6 , and even 4.4 gearing, they get faster than 65mph, and do loadsa miles on rapidos. ive rode a few, but the first time ive had one on my own scooter, so quite looking forward to using it this year.its getting about 75 miles to a standard tank at mainly full belt, so not as juicy as i was expecting.
Much appreciated, thanks :)
