Page 2 of 2
Re: 200 running rough
Posted: Sun Mar 21, 2010 12:57 am
by rog60
engine only running with choke on is a good sign of main jet blocked.............in fact take carb apart thoroughly clean in petrol/parafin, blow all jets through with air line and re-assemble making sure that all parts are scrupulously clean on re-assembly.....................
P.S. also ensure that atomiser has not unscrewed..........happened to me once.
Posted: Sun Mar 21, 2010 4:50 am
by lifes a drag
do you know anybody else with the same spec scoot as yours so you could borrow there carb to see how yours runs then ?
Posted: Mon Mar 22, 2010 9:38 pm
by lee b
my jetex too had a 'boggy' problem,found a lump of plastic stuck i main jet.
cleaned and fine after that.
Posted: Wed Mar 24, 2010 10:40 am
by joda
Thanks for all the replys!
i have since stripped the carb, cleaned it, rebuilt it, same again
i then fitted another carb from a friends scooter, same problem
have spoken to another guy who recons its the oilseal thats away, so is planning some surgery in the coming weeks!
thanks again
Posted: Mon Apr 19, 2010 1:46 pm
by Andy Cowhig
Did you ever find the problem as I am having similar symptoms?
See mine :
http://scooterotica.org/forum/viewtopic ... 062#p69062
Andy
Posted: Mon Apr 19, 2010 2:03 pm
by joda
yes found out the problem!
the guy who fixed it said that it had a bearing and seal from a gp fitted onto the sx crank, which caused the seal to eventually blow
was rebuilt and so far its ok!
