Page 2 of 2
Re: Which Fuel filter?
Posted: Mon Mar 15, 2010 10:49 am
by red ghost
Mel K wrote:I think an inline filter, no matter how good, will, and have done, restrict fuel, especially when it gets a bit clogged and the only way you will know it's clogged hurtling along at speed is when you seize?
Isn't that where regular service and maintainence comes into play?
Also the Pingle filters are aimed at Harleys and the like,so our little couple hundred CC's scoots will be fine.
Posted: Mon Mar 15, 2010 2:36 pm
by Mel K
red ghost wrote:Mel K wrote:I think an inline filter, no matter how good, will, and have done, restrict fuel, especially when it gets a bit clogged and the only way you will know it's clogged hurtling along at speed is when you seize?
red ghost, of course regular maintainence comes into play, but if you're riding 1500 miles over 4 days are you going to check your filter every time you fill up? I doubt it. That's why I suggested a fuel filler filter. At least this way some effort has been made to filter the fuel as it's going in the tank reducing the need for an inline filter which can restrict your flow.
Posted: Mon Mar 15, 2010 2:52 pm
by dapper
[quote="Mel K"]Scootrs do a filter you put in the tank inlet when filling up, you'd be surprised how much crap it stops from gettin into the tank in the first place
only a couple of quid too
I think an inline filter, no matter how good, will, and have done, restrict fuel, especially when it gets a bit clogged and the only way you will know it's clogged hurtling along at speed is when you seize? Just my thoughts on the subject. :bald: Hope this helps
[/quot
Just looked on ScootRS site and couldn't see a petrol tank filter!! Can you point me to it?
Posted: Mon Mar 15, 2010 3:43 pm
by C*NTSPEED
dapper wrote:Mel K wrote:Scootrs do a filter you put in the tank inlet when filling up, you'd be surprised how much crap it stops from gettin into the tank in the first place
[/quot
id leave that well alone its that shallow and has a solid bottom to it so when you fill up you have to do so at a trickle or it pisses out all over the place.....only my opinion of course
Posted: Mon Mar 15, 2010 3:50 pm
by dapper
Did wonder
Posted: Mon Mar 15, 2010 11:07 pm
by Honeymonster
Dazza, Cottage Lambretta do a chrome/glass inline fuel filter @ £10, a mate picked me one up from Wickstead, looks Ok but fairly large, using it with a rear exit fast flow tap on a standard tank with a TM 24 with 190 main, no fuel supply problems encountered so far.
Ian
Posted: Tue Mar 16, 2010 9:53 am
by eibargum
All fillters that are doing thier job will restrict flow to some extent but Dazza and myself have changed fuel tanks and are going to run a fillter [in dazza,s case, he says a few hundred miles] in my case a couple of hundred, just to see what if anything is coming out of the tank, iam also running a Mikuni [as is Dazza] and they dont have a built in fillter like Dellys do, how many of you regularly check your fillter in the Dellys, none
, unless your taking it to bits to do another job, i,ll be checking mine every time we stop for a p155 on the way to Whitby
, and at my age, thats pretty often
Posted: Tue Mar 16, 2010 10:13 am
by C*NTSPEED
eibargum wrote:All fillters that are doing thier job will restrict flow to some extent but Dazza and myself have changed fuel tanks and are going to run a fillter [in dazza,s case, he says a few hundred miles] in my case a couple of hundred, just to see what if anything is coming out of the tank, iam also running a Mikuni [as is Dazza] and they dont have a built in fillter like Dellys do, how many of you regularly check your fillter in the Dellys, none
but as mark says 8mm pipe and the filter he suggested will allow more fuel to pass than the 6mm wont it so in theory no it wont restrict!
Posted: Tue Mar 16, 2010 3:52 pm
by dirtyhandslopez
I am sure flowage is an issue, but I have alway had vapor locking /frothing problems on any scoots I have seen with in-line filters. A clean system is definately the way to go.
