Page 2 of 2
Re: Lynx flasher question
Posted: Sun May 16, 2010 6:08 am
by lammydave
firekdp wrote:Connect it to the purple wire, which goes from the relay to the headset indicator warning lamp.
is there a headset indicator warning lamp??
my jet doesnt have one, just neutral, lights on, and high beam......
Posted: Sun May 16, 2010 9:53 am
by storkfoot
Kev, when I had it wired to the grey, I held the other end to the purple and got nothing. But then the orange indicator light on the headset has never worked either (I've tried 2 bulbs). The only light on the headset that does work is the main/ dipped bean one as the neutral switch is faulty.
Is there a workaround or do I have to find why the orange indicator light on the headset is not activated by the indicators flashing?
Thanks again ;)
Paul
PS, lammydave, I think your headset lights are probably correct. My Lynx is wired to a diagram that used the headight on/off light (which is pretty pointless anyway) as a light which flashed with the indicators. This was, I believe, a popular modification at the time and, later Lynxes may have been wired like this anyway
Posted: Sun May 16, 2010 10:21 am
by firekdp
Paul, the buzzer should work if it is fitted between the purple and earth, not between purple & grey as when the relay activates these two wires are shorted together.
Posted: Sun May 16, 2010 3:32 pm
by storkfoot
Kev, just tried this and the indicator continues to work but no buzzer. I swapped the leads over from the buzzer and just the same.
I have one lead from the buzzer fitted to a connector in the purple, not far from the relay itself, and the other lead earthed to the back to the legshields.
This is the buzzer:
http://www.maplin.co.uk/Module.aspx?ModuleNo=3213
Posted: Sun May 16, 2010 11:41 pm
by firekdp
Paul, you'll have to remind me which relay you've got.
Posted: Mon May 17, 2010 7:41 am
by storkfoot
Posted: Mon May 17, 2010 6:44 pm
by firekdp
If the earth connection you made, for the buzzer, is good then it can only be a fault with the relay. When the relay latches the "R" connection should be directly connected to the "+" connector, so when the indicators flash all 3 connectors should be joined.
