Re: Upper front fork damper brackets
Posted: Thu Mar 11, 2010 3:37 pm
ian your a fcuking star rapid dont supply them to pubic but to heresoullad wrote:I have found that instead of using the typical shouldered link stud, which pushed the lower end of the damper away from the fork link you can just use a stud thats 7mm one end and 6mm the other.
Screw the 7mm into the fork link as far as you can with the double nut method. Then slide on a "penny" washer then your damper......its looks alot neater and lines up with your top brackets more oftern than not.
Terry White at Rapid Industrial Fasteners can supply these studs.
Worth a go?
http://beedspeed.com/product_info.php?c ... ts_id=8227
my idea was a long inlet stud and turn one end down and thread it but this might be better the only thing the shank is 7mm and the damper eye is 13-15 mm depending on type
