Re: loose exhaust nuts
Posted: Mon Mar 08, 2010 9:56 pm
Good idea and the one I use but I fold the long tab over the edge of the flange.shocky wrote:
To stop the tab washer itself moving?soulsurfer wrote:Good idea and the one I use but I fold the long tab over the edge of the flange.shocky wrote:
I had those and they seemed to loosen and allow the flange to blow, but it's tightening hi tensile bolts into ally that I wasn't too keen on, especially if removing the manifold all the time to stop it leakingSpecial X wrote:Taffs (or rather the guys who took over the shop) sell wire lockable allen bolts which are a great idea as there's no stud to come loose.
you gota look after your engine this was a home brew ts 240 it vibrated itself to death(after10k miles) the drive side bearing journal went oval and a large crack formedlofty wrote:i just like the fact that shocky puts his engine to bed in a pink blanket.. ahhhh!
don't say that I've just fitted a pair of Taffy bolts.......took me ages to lockwire them too....thought that this would be the answer and I'd never have to lay down under the engine with an 11mm spanner ever again?soulsurfer wrote:I had those and they seemed to loosen and allow the flange to blow, but it's tightening hi tensile bolts into ally that I wasn't too keen on, especially if removing the manifold all the time to stop it leakingSpecial X wrote:Taffs (or rather the guys who took over the shop) sell wire lockable allen bolts which are a great idea as there's no stud to come loose.
