Page 2 of 2
Re: No brake light
Posted: Thu Mar 04, 2010 10:28 pm
by rog60
byron wrote:^yep
and also use your multimeter to test the switch
remembering that there should be continuity when the pin is out
And make sure you've got a good earth to frame from reflector.................
Re: No brake light
Posted: Fri Mar 05, 2010 3:56 pm
by Bilko
Went out the morning to have another look and for whatever reason, the back light and brake light work. A bit frustrating without knowing the cause. I'll keep a close eye on it.
Thanks for all the help. :)
Re: No brake light
Posted: Fri Mar 05, 2010 9:29 pm
by Fireman Ash
Check yer bulb as they can be faulty and intermittant, happened to me at the MOT station. I always use a multi meter now as previously suggested..
