JL3 RIVETS
Fruitjuice
When buying the rivets, check that both the rivets and the nails are stainless, as this is not always the case...
lockman69
Dazza wrote: it does take a lot of effort.
That's fecked then, eh burridge01! :D :lol: :D
wack 63
Main scooter: '71 GP TS1
Instead of messing about with rivets all the time why not weld nuts inside the end cap and use stainless button head M5 Allen screws.Its a lot easier whenever you need to repack tailpipe and using a dab of loctite they never come loose like rivets. You can MIG weld to stainless easy enough.
burridge01
wack 63 wrote:Instead of messing about with rivets all the time why not weld nuts inside the end cap and use stainless button head M5 Allen screws.Its a lot easier whenever you need to repack tailpipe and using a dab of loctite they never come loose like rivets. You can MIG weld to stainless easy enough.
Easer said then done flower :frog:
Brighton F.C-LOL
burridge01
uYou'v got my number you cant :mrgreen: :mrgreen:
Brighton F.C-LOL
