Page 2 of 3
Re: R1 rear shock
Posted: Wed Feb 17, 2010 12:19 am
by pasner
Double thin nuts? nyloc half nuts? who sells that?
Re: R1 rear shock
Posted: Wed Feb 17, 2010 1:03 am
by Chris CSPE
Go for the BGM shocker, not only do they look good but there very easy to set up right, and most importantly if anything goes wrong its easily sorted out, used alot of these and had no problems on the later ones but had two that leaked when they first came out.
Re: R1 rear shock
Posted: Wed Feb 17, 2010 12:47 pm
by mick the brush
Re: R1 rear shock
Posted: Wed Feb 17, 2010 1:41 pm
by DJB
NO a Hagon or an escorts
GVFM
Re: R1 rear shock
Posted: Thu Feb 18, 2010 6:48 pm
by chiggy03
I've got stainless nyloc half nut kits if anyone's interested?
Re: R1 rear shock
Posted: Thu Feb 18, 2010 7:49 pm
by pasner
Thanx, I can be interested.
Re: R1 rear shock
Posted: Sat Feb 20, 2010 10:30 pm
by Bufficus
sean brady scooters wrote:whilst the nuts need to be tight obviosly,they should not tighten up against the shocker bushes and so restrict the slight amount of movement that they require under suspension movement....
Interesting, I have brass bushes fitted to mine, supplied by Foxy, mine are done up tight, but the shock pivots freely around the bushes. Has done for years. Is this bad?
BTW. I don't think there's much wrong with the good old Escort. Unless they start to leak that is.
Re: R1 rear shock
Posted: Sat Feb 20, 2010 10:53 pm
by Dazza
chiggy03 wrote:Why not use nyloc half nuts?
Some stainless ones would be nice
Got them in yet Chiggy?
Re: R1 rear shock
Posted: Sun Feb 21, 2010 12:08 am
by chiggy03
Yes mate, picked them up Yesterday. Limited supplies until next weekend - 10 sets. Toddy's ordered 4 to be picked up at donny Tomorrow, Rob Burns paid for 1 set and 1 set sold through ebay....... get them while they're hot, hot, hot!!!
Re: R1 rear shock
Posted: Sun Feb 21, 2010 9:59 am
by soulsurfer
Bufficus wrote:Interesting, I have brass bushes fitted to mine, supplied by Foxy, mine are done up tight, but the shock pivots freely around the bushes. Has done for years. Is this bad?
Not good as this makes the shock rigid from side to side as the engine flexes on the engine mounts. This can result in a broken shock.
