R1 rear shock
pasner
Double thin nuts? nyloc half nuts? who sells that?
Chris CSPE
Go for the BGM shocker, not only do they look good but there very easy to set up right, and most importantly if anything goes wrong its easily sorted out, used alot of these and had no problems on the later ones but had two that leaked when they first came out.
mick the brush
right!!! so its a bgm shock with two double thin nuts and half nylock then :D :D :D
the smell of solvents, t'is what makes me happy!!!
DJB
mick the brush wrote:right!!! so its a bgm shock with two double thin nuts and half nylock then :D :D :D
NO a Hagon or an escorts ;) GVFM
chiggy03
I've got stainless nyloc half nut kits if anyone's interested?
pasner
Thanx, I can be interested.
Bufficus
sean brady scooters wrote:whilst the nuts need to be tight obviosly,they should not tighten up against the shocker bushes and so restrict the slight amount of movement that they require under suspension movement....
Interesting, I have brass bushes fitted to mine, supplied by Foxy, mine are done up tight, but the shock pivots freely around the bushes. Has done for years. Is this bad? :?
BTW. I don't think there's much wrong with the good old Escort. Unless they start to leak that is.
Dazza
chiggy03 wrote:Why not use nyloc half nuts?
Some stainless ones would be nice ;) Got them in yet Chiggy?
chiggy03
Yes mate, picked them up Yesterday. Limited supplies until next weekend - 10 sets. Toddy's ordered 4 to be picked up at donny Tomorrow, Rob Burns paid for 1 set and 1 set sold through ebay....... get them while they're hot, hot, hot!!!
Bufficus wrote:Interesting, I have brass bushes fitted to mine, supplied by Foxy, mine are done up tight, but the shock pivots freely around the bushes. Has done for years. Is this bad? :?
Not good as this makes the shock rigid from side to side as the engine flexes on the engine mounts. This can result in a broken shock.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
