revs problem
what do you mean ,"what do i mean"..... :lol:
its quite simple.....
put in a small hole into the lowest point of your air hose/bellows....
this will of course allow excess fuel build up to drain out....and prevent flooding...
roadrunnerian
thanks everyone for there replies a lot to think about thanks again
minotaur
think i had the same problem as you a couple of years ago on my gp with pwk carb. the float height needed adjusting ever so slightly and it flooded sometimes a little, fuel build up at the bottom of bellows where it meets carb mouth. i used to turn off fuel just b4 i turned off motor , and turn back on just after firing until i sorted float, the pin hole idea would work also,
