Qustom Daytone front damper
or the frank sanderson set up
My question is why are you unhappy with you current set-up? Might not be the case here, but I think most people want to upgrade their dampers after fitting a hydraulic front brake, and then experiencing dive on braking. These dampers won't help with this much. What you need is anti dive, then standard dampers will suffice.
