it fits in the front hub as well
just got to fit foot pedal master and pipe it up
i have straightened the slave and sorted the circlips before you say anything
cam?if you have a cam, -would buy one.
so no different to the standard setup then...mark wrote: only thing im concerned about is there is no room for an auto adjuster so will just have to keep an eye on thickness of shoes
The cylinders were cast steel so were prone to rusting due to water being absorbed into the brake fluid which hastened the faiulure of the seals. If synthetic brake fluid is iused that won't be a problem.Lam46 wrote:Its a very similar set up to the old mini, from memory its called a slave cylinder but on the minis they where prone to blowing seals..(cheap s**t no doubt) I remember cause I owned and changed a few..
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 9 guests
