Page 2 of 3
Re: engine out
Posted: Tue Dec 29, 2009 10:52 pm
by rakki
Cool to see someone avoiding special tools in favour of creative brute force methods.
Re: engine out
Posted: Tue Dec 29, 2009 10:56 pm
by sean brady scooters
i did not like to mention that myself,but its the first time i have ever seen a 5 ton hydraulic press used to compress a lambretta clutch.....
he must have had some really strong springs in there.... :lol:
Re: engine out
Posted: Tue Dec 29, 2009 11:16 pm
by iMotors
:D It is pneumatically actuated and i´ve got a knob to controll it very acuratelly.
boat gearboxes are my bread and butter and i´ve developed a fine sense to operate it.
Re: engine out
Posted: Tue Dec 29, 2009 11:43 pm
good for you matey...
but the impact driver on the clutch also made me cringe....have you not got any proper tools ...?
Re: engine out
Posted: Fri Jan 01, 2010 8:15 pm
by dirtyhandslopez
sean brady scooters wrote:good for you matey...
Dunno about that. I've been using a small air gun on the flywheel nuts and clutch nuts for years. Got a half inch gun for the hub nut to get it near torque, then torque properly. 1/4" impact rachet for the tank bolts and chaincase studs. It just saves so much time I reckon. BTW, they are proper tools, not plastic ones :)
Re: engine out
Posted: Fri Jan 01, 2010 8:26 pm
ive nothing against air tools/impact sockets etc at all...(especially in the dismantling stage) ,but in say a flywheel or clutch sprocket scenario....the proper holding tools would still make the job easier and safer would it not.. :lol:
but more importantly in the rebuilding stage,the holding tools are needed to assure the proper torque settings.. :D
Re: engine out
Posted: Tue Jan 05, 2010 5:33 pm
by dirtyhandslopez
sean brady scooters wrote:ive nothing against air tools/impact sockets etc at all...(especially in the dismantling stage) ,but in say a flywheel or clutch sprocket scenario....the proper holding tools would still make the job easier and safer would it not.. :lol:
Call me a bad person, but I have never actually torqued the clutch nut or the crank bolt. Tightened up tight, absolutely. Clutch nut has the lock washer and the crank bolt tightens when it spins.
The side casing with the funny looking crack at the crank bolt area was being set up for a crank driven tacho, honest ;)
Re: engine out
Posted: Thu Jan 07, 2010 1:48 pm
by iMotors
Clutch cleaned for inspection...
Finally i´ll change all bearings and seals, rebore the cylinder and a new piston and clutch.
Re: engine out
Posted: Sun Mar 21, 2010 12:20 am
by iMotors
Finally i get a bit of spare time and close my case, new bearings, seals and clutch.
Clutch spider before and after some work with the file...
Compressing the new clutch
Closed case, now is time to port and fit my new 175 cylinder
Re: engine out
Posted: Sun Mar 21, 2010 4:39 pm
by iMotors
This is very close to definitive decoration, the vertical stripes will go to the front, and i am guessing wich colour for the rims, red, black, silver, blue...
Any ideas????
