problem,Help
oggy
going to work now ,tel 07773059897 to grt a piccy . cheers or if near cov i will bring it round.
2mm from edge of rim to the sticking out bit that runs round the tyre..if your fitting it on the back you might need MB spacers or they can ru on the engine casing...mine does a bit.
oggy wrote:going to work now ,tel 07773059897 to grt a piccy . cheers or if near cov i will bring it round.
Couple of pics on the way..hope they help, going to work now.. :( , Ive finished today.. :D
andylaw7
watching a biker type programme a while ago and this old biker put pledge around the rim before he put tyre on ,tried it meself works a treat .
andylaw7 wrote:watching a biker type programme a while ago and this old biker put pledge around the rim before he put tyre on ,tried it meself works a treat .
I use hand soap, which afaik is pretty much what is used for fitting at tyre depots... but without the smells
good old "fairy washing up liquid "does the trick too
Dazza
Just pump it until you start wincing at the prospect of it going BANG it should pop into place. :D
A good tip which I have used for yonks is to wipe silicon sealer all round the inside of the rim, while it's still 'wet' it will help the tyre slide on and once cured will not allow the tyre to spin if you've got a higher powered bike like other lubricants may.
It may even be argued it might help keep the rust at bay - I also squirt a bead around the rim before bolting together .
It doesn't make it too much harder to separate the halves later on either.
oldbiker
Dazza wrote:silicon sealer all round the inside of the rim, while it's still 'wet' ......
That sounds like a bloody good idea :idea:
I will remember that one for future use. Even though soapy stuff is the norm
    Users browsing this forum: No registered users and 57 guests
