Add On Box - Augusto Unit - Varitronic System
noggin1969
Justed ordered one off E.bay from JB for the TS1 so i'll give it a go and let you know
Has a mind full of useless s**t and isn't afraid to use it !
did you go for the 7000 model then ?
noggin1969
yes ,
CANbus
drunkmunkey6969 wrote:As i understand it these are all variations on a theme...the theme being Lambrettas run static ignition timing and these boxes/systems bring a degree of flexibility in terms of variable ignition timing.I however have never used any of these systems, but am very interested in fitting an Augusto unit to my racer. If i understand correctly, it will help to improve the bottom end & mid range power.
But if anyone out there can give me information on the various systems, their spec/prices/benefits/pitfalls etc i'd be very grateful.....it would be good to get a complete picture of each (and any other) system so that we can make comparison and see which system suits which application/purpose best.
I would also appreciate if someone would also explain the principle how this flexibility is a achieved, I wish to add this functionality to a control system project I have on the go currently.
Thanks.
11111111 = 0xFF
ArmandTanzarian
What are the different versions and what are the differences between them? I've only ever seen the 7000 for sale.
paulmgreen
there are 6000, 7000,80000
versions.
Basically depending upon state of tune / max revs.
6000 - standard engines
7000 - kitted engines - low level of tune
8000 - tuned engines higher revving
www.JPPLambretta.co.uk
rossi46
I went with the 8000 as mine is an RB this was recommended to me.
nastro azzurro
Got one on my RB, an 8000 model. Ive done about 700 miles with it now. I ran my engine in without it and had it fitted after. The noticable difference is that you can just dial the power in and the whole engine feels smoother, if that makes sense! For the gains you get its a cheap piece of kit IMO.
matthew
I've got a 7000 for my TS1 but yet to fit it, I'll let you know what difference it makes once it's on.
Matt
Lamaddict
6000 one for me for me - Stage 4 ( SIL), Yam 110 rod, lighter piston, Mikuni 24mm, Af Clubman and Li 125 gearbox 18X47. Nearly went for the 7000 but was recommended the 6000. The science looks good and it will hopefully make a smooth, economic and reasonable quick engine.
