Page 2 of 2
Re: GIJON Show your ride!
Posted: Sat Dec 05, 2009 7:00 pm
by coaster
Here's mine, bought off Shocky, 82 Jet. Since that photo I have compeltely stripped it and had it blasted. I'm currently repairing panels prior to respray. It came with an Indian 150 but I am building up a 225 to put in it
Posted: Fri Dec 18, 2009 9:53 pm
by teamsequipe
Just the engine pics so far....
That exhaust could only come from a very twisted mind ......... Simon, we need to swap movie lists very soon !
This will be going into my GP125 S Type Frame, and the 190 motor given a bit of a rest...... I intend to do some more enhancing of this little GP over the next few weeks in readiness for Spain, and next season, so I'll try and get more pics up soon.
Cheers everyone
Darrell
Posted: Fri Dec 18, 2009 10:03 pm
by sean brady scooters
whats going on there....looks interesting
Posted: Fri Dec 18, 2009 10:41 pm
by J1MS
Did the flywheel lose a fin by accident so you balanced it out, or was it done on purpose and for a reason??
Posted: Fri Dec 18, 2009 10:55 pm
whats the reasoning/theory as regards the plating around the crankcase area...?
i can see that a lot of time and effort has been put into this ,but dont understand why.
i,m sure you have a good reason for doing this though and so hopefully you could explain....
also ,does this system use internal baffles,hence just a tail pipe and no silencer....
Posted: Fri Dec 18, 2009 11:38 pm
by teamsequipe
sean brady scooters wrote:whats the reasoning/theory as regards the plating around the crankcase area...?
Take a closer look........... the crankcase hasn't been plated, it's all exhaust !
The flywheel has been lightened, and then some.......... it's now perfectly balanced.
All I need to do now is modify some old cowlings I've got to fit over everything.......... wonder what BRM Speedwell's up to Sunday evening ...........
Posted: Sat Dec 19, 2009 12:30 am
by Soulpunk
i would like to know more about the exhaust...
whats the story behind it (inspiration, data)
Posted: Sat Dec 19, 2009 1:29 pm
by mark
i have a choice of 3 all need building properly yet tho
:biggrin:
this is in lots of bits .
this needs rebuilding but is favourite to be ready with a pav
and this needs finishing
