Page 2 of 2
Re: Tino saachi belt drive system.
Posted: Wed Nov 18, 2009 7:58 pm
by J1MS
That looks very well made, Tino Saachi does seem to have an ability to produce what others would struggle to just imagine...
The adjuster does look very much like a modified version that Charlie Emdunds currently uses on his group 4 race scooter with two bearings and a neatly machined nylon roller adjusting the chain inwards (on Charlies) instead of pushing outwards as on standards scooters to remove slack.
Just maybe, Charlie might have had a look at this while it was in the design stage :?:
Posted: Thu Nov 19, 2009 2:34 am
by damdam
I got a flyer of that kit I took directly from Tino Sacchi, who I met on a scooter custom show 2 weeks ago here in Italy (Tino was also showing the kit itself)
I can try to scan it
Posted: Thu Nov 19, 2009 3:21 am
by RICSPEED
6LDA 28B wrote:I had a ktm with a 560cc rotax engine it had a cam belt that would run problem free as long as the pulley wheels were fitted correctly just a few mm out and it would shred the belt in minutes.
Could the Tino have a dry clutch and a sealed gearbox end plate
You need a hole in the end plate for the kickstart
