Page 2 of 2
Re: Fork Links
Posted: Sun Nov 15, 2009 12:42 am
by shocky
rog60 wrote:Bloody hell mate, they're better than my 'made as original' links. :o :o :o
ware were they from
Re: Fork Links
Posted: Sun Nov 15, 2009 1:15 am
by rog60
ware were they from
Dunno, were on scoot when I bought it, probably Viet. Although had no problems and seem strong...........................
Re: Fork Links
Posted: Fri Nov 20, 2009 10:25 pm
by Monty
Just had a set back from Shocky. The quality of his welding is top notch, plating is great. So much better doing this than useing those bloody bolt on plates
Thanks Shocky
Monty
Re: Fork Links
Posted: Sat Nov 21, 2009 6:24 pm
by sydduckett
Steves got my set and hopfully back for next weekend then the re-build can start again... :D
Re: Fork Links
Posted: Sat Nov 21, 2009 6:27 pm
by carlos fandango
Ive had some from shocky as well :D and i can highly recommend :D :D
Re: Fork Links
Posted: Sat Nov 21, 2009 10:15 pm
by soullad
He's also been known to convert the odd shock or two ..... :lol: well recommended. Pm sent mate.
Re: Fork Links
Posted: Sun Nov 22, 2009 9:22 am
by colski
Thanks for your posts guys. I have PM shocky and will be sending him mine to do.
Col :mrgreen:
Re: Fork Links
Posted: Sun Nov 22, 2009 1:02 pm
by Stampede
byron wrote:as long as your links are Italian or Spanish
Shocky is the man for the welding
why is the welding impossible for indian ones?
Re: Fork Links
Posted: Sun Nov 22, 2009 1:46 pm
by shocky
i wouldnt say it was but frank sanderson had some welded and dropped one the lug just cracked off also when the links have been fitted the end were the hub goes has snapped off
if you have a set and want them welded i can do it no problem i suspect they would be ok on a standard machine
if i did some and they broke i would loose some of the faith others put in my work i always try and resolve any problems of anything i supply im not a dealer just do a few things in my spare time and if there is a prob i usually take a hit
Re: Fork Links
Posted: Sun Nov 22, 2009 6:14 pm
by storkfoot
The quality of the metal is not as good which makes the links wharp when welded.
I've had 3 sets of damper mounts welded to Italian links with no problems. The one set of Indian ones I had welded looked OK, however, they wharped and sent the fork links out of plane. Definitely avoid welding Indian links
