gear box chatter
darren112
good tips knowledge like it . but the kick start is not engaging on first gear . with engine running put hand on kickstart push down 1/2 inch and then the plunger engages 1st gear .gp end plt . had no problems until i changed gear boxes. :)
Lazarus
Hi Darren
I had what sounds like the same problem with my GP when I changed the 150 GP box for an Li 150 one and after lots of changed parts and adjustments shims etc it was fixed the way knowledge said.
darren112
Lazarus wrote:Hi Darren
hi lazarus found filings on magnetic drain plug too much for 10 miles . so this evening stripped the back end out .and found the new pressure plt not running freely as i thought in the spider .so a bit more fettling on that department.the gearbox looks fine .but think the sliding dog could do with replacing .but have seen worse in use . and trying another :) gearbox
