Page 2 of 2
Re: who sells sil rear hubs?
Posted: Fri Oct 30, 2009 9:30 am
by col265
I had a scootRS rim on a Spanish hub - no problem.
Posted: Fri Oct 30, 2009 10:09 am
by cezeta
thats what a few people have said but mine do not go on, mbd withdrew supplying them for the same reason i was told and everybody I know has the same problem with spanish hubs.
i will grab a bub and a rim as we speak and see if i can see why but by memory its the larger tabs that hold the studs that will not go into the rims
Posted: Fri Oct 30, 2009 10:26 am
by cezeta
yes, just tried on a 74 jet 200 hub and a 79 150 special hub. its the lugs that hold the stids on which if you lay an italian hub over a spanish hub you can see the differance.
even with a tap with a copper hammer....no way Hosey.
Posted: Fri Oct 30, 2009 1:09 pm
by Stokie
cezeta wrote:....no way Hosey.
If you're talking about Spanish rims then you really should get "José" correct ! ;) :D
