Page 2 of 2
Re: piston change
Posted: Mon Oct 26, 2009 5:50 pm
by RinB
joespeed wrote:
both these pistons are cheap cheap,both quality and price you really need one from mr broadhirst or an af one
I recommend dont use these pistons on any stage 4 tune the rings cant handle it
I know from experience
Go the ASSO route or Mahle Piston with Asso rings costs £65 ish
Remember the Asso 66mm has the 3mm off the skirt, so need to take this into account
when doing the tuning Mahle piston doesnt.
Im at present doing 4 200cc st4 for people and this is the route Ive gone
Re: piston change
Posted: Mon Oct 26, 2009 7:32 pm
by oldbiker
when tuning any two stroke I would always try to get a nice jap piston, for all the following reasons (thin rings, light weight, better piston strength, more accurate machining, easy availability, etc.etc.etc)
Re: piston change
Posted: Tue Oct 27, 2009 4:07 pm
by C*NTSPEED
tzr.steve wrote:when tuning any two stroke I would always try to get a nice jap piston, for all the following reasons (thin rings, light weight, better piston strength, more accurate machining, easy availability, etc.etc.etc)
this is what im trying to do
Re: piston change
Posted: Wed Oct 28, 2009 10:42 am
by jonny snatchsniffer
is that for the ts200 you said about ? as the yam dt/it piston is 66mm and some kawasaki ones are 66mm too
Re: piston change
Posted: Wed Oct 28, 2009 10:56 am
by Fruitjuice
jonny snatchsniffer wrote:is that for the ts200 you said about ? as the yam dt/it piston is 66mm and some kawasaki ones are 66mm too
Yamaha IT175/YZ175 pistons are very good and will only fit a TS1/Monza 200 kit when using a 115/116 rod because of a different deck height.
Re: piston change
Posted: Wed Oct 28, 2009 12:16 pm
unless you wanna top and tail or stroke it to your personal needs
Re: piston change
Posted: Wed Oct 28, 2009 12:43 pm
by bazman
sean brady scooters wrote:i,m sure bazman ran the mahle piston.............
I certainly did sean
On hols at the moment so would have replied earlier.....
Re: piston change
Posted: Fri Oct 30, 2009 8:50 pm
by Tosh
thanks chaps for all the replies,going to go the mahle route but what still puzies me is how do i make sure i get the right size piston/rings or do i take the barrel with me when i go to buy one
Re: piston change
Posted: Fri Oct 30, 2009 9:00 pm
by bazman
You need to measure the bore of the barrel and get piston to suit
Re: piston change
Posted: Sat Oct 31, 2009 4:34 pm
by Tosh
thanks bazman for that ,i bet sean thinks i`m never going to get hold of him and try to sort a tune out
