Page 2 of 2
Re: PWK for RB20
Posted: Fri Oct 16, 2009 4:09 pm
by MarkH
No, not the same. They probably just used whatever images they had.
The stage6 look to be YSN as well - not 100% sure.
Re: PWK for RB20
Posted: Fri Oct 16, 2009 4:17 pm
by ArKaTxU
wrekkah wrote:...... I feel a TMX35 is too big and a TM24 too small for the RB20. Anyone else have an opinion on this?.....
Do you think that TMX35 is too big for the RB20? i have read a lot of people on forums using this carb in this kit. AF i think that recommend a 34 Dellorto for this kit.
The TMX35 have too good panel clearance if you dont want to do a hole in the panel.
Cheers.
Re: PWK for RB20
Posted: Fri Oct 16, 2009 4:28 pm
by jonny snatchsniffer
you can always use the tmx27 or tmx30, if it was me id put a 34mm on it, you want it to breathe and as for fuel economy you dont buy an rb for that, you get a honda c70
Re: PWK for RB20
Posted: Fri Oct 16, 2009 9:06 pm
by wrekkah
Thanks for the info. I'll search for info about running a TMX35 on an RB20. If anyone has any experience with this combo I'd appreciate hearing from you.
In the states, some of the other size carbs mentioned aren't readily available, or at least I haven't found a supplier. Obviously I can buy from overseas but it can get pretty pricey with the exchange rate and fees. That's why I'd like to stick with one of the carbs Jet200 sells. When I bought my RB kit the UPS guy showed up at my door and asked me for another $50 to release the package. Gave me some excuse about duty fees.
Re: PWK for RB20
Posted: Sat Oct 17, 2009 10:06 am
cant you get someone in the uk to buy it for you then have it sent to you as a present and saying it only cost £5
