Page 2 of 2
Re: Recommendation for parting tool
Posted: Mon Sep 28, 2009 8:26 pm
by sideout
davidblythe wrote:
sideout wrote:David
HSS tools are fine. Just make sure the rake angle suits the material being parted off.
Cheers,
Nigel
Hi Nigel
more detail here please,
cheers david
More detail (just repeating what Markd232 said really):
Aluminium Alloys required a steeper rake angle 10-20 degrees (the top surface of the cutting edge with respect to horizontal) than steel.
Also, the relief angle (the front surface of the cutting edge with respect to vertical) would be about 8-12 degrees.
Mark's comment about "front cutting edge is ground at an angle of 5 degrees and not square" is good advice too. It ensures the bit you are parting off comes away cleanly without any remedial work required.
Hope the above helps.
Nigel
Posted: Tue Sep 29, 2009 9:46 am
by davidblythe
Mark,
the fax were spot on and very useful, :bouncing:
Posted: Tue Sep 29, 2009 9:49 am
by davidblythe
sideout wrote:
davidblythe wrote:
sideout wrote:David
Cheers,
Nigel
Hi Nigel
cheers david
Nigel
Cheers Nigel,
starting to enjoy using the lathe now, working cleaner with the parting tool now
Posted: Tue Sep 29, 2009 10:00 am
by markd232
No problem Dave, hope you have some fun, nothing better than designing, manufacturing and then using a part you made yourself.
