Re: Finless Flywheel
Posted: Wed Sep 16, 2009 8:58 pm
so are you going for scoop cooling or watercooling?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
If you were going to ditch the fan and just run a scoop, Would you change the head for one with a better designed cooling fin (Like the Villiers head) to go with the scoop, or do you think the standard type head fitted with a scoop would cool well enough..??paulmgreen wrote:so are you going for scoop cooling or watercooling?
Sorry Bilco, I don't know the answer, I was just guessing as to why you wanted know and 2nd guessing a fixBilko wrote:Hello Coaster, no it's not for a fan, there will be no fan. But am I right in thinking from your reply that without the fins and fin housing, it doesn't protrude from the mag housing?
Bilko's head hurts, so he has another pint of Guinness and goes to bed.Bilko wrote:Bilko takes note of the post by Sean of Sean Brady's Scooters. He moves to the drawing room and takes out his abacus and studies the figures laid out in front of him..
