I got an electric shock when i switched my lights on? Help!
firekdp
If the green wire was touching touching the frame the scooter would'nt run as the ignition would be earthed. If the green was shorting inside the switch to its casing then the paint on the headset would insulate it, but when you touch it you complete the earth path.
J1MS
^^^Thats what I thought^^^
wax
I found that the yellow wire inside the headset is the one that gives me an electric shock. I have disconnected it for now. Maybe the feed from the green is shorting out inside the switch? How does this sound?
rbgaz
dont ride at night ;)
