Re: Viton Oil Seals..??
Posted: Mon Aug 17, 2009 8:39 pm
Fluoroelastomers (FPM/FKM)
Well known compounds include Viton® from DuPont Performance Elastomers, Tecnoflon® from Ausimont Spa, and Dyneon® from 3M Dyneon.
Chemical properties
Fluoroelastomers operate efficiently under severe chemical conditions and at higher temperatures where many other seal materials cannot survive. According to grade, they are well suited to arduous conditions with petroleum fuels and mineral-based hydraulic fluids, and many solvents.
Typical operating temperatures
-15°C to +200°C continuous, or +230°C intermittent. Some grades are available for temperatures from -30°C to +250°C.
General purpose fluoroelastomers
FR10: Dipolymer-based range with hardnesses of 50-90 IRHD. These grades are ideal for general applications and are approved to UK Ministry of Defence low compression set specifications.
FR17: Terpolymer-based range with hardnesses of 65-95 IRHD. This range has better high temperature flexibility characteristics than FR10, although these properties are - to some extent - at the expense of compression set resistance.
FR44: Dipolymer-based range with hardnesses of 50-90 IRHD. This range comes in a distinctive shade of green for easy identification. These low compression set grades meet many regularly used specifications.
Special fluoroelastomer grades
FR58/90 & 98: These terpolymer-based grades are rapid gas decompression (RGD) resistant for oilfield duties, and have good all round elastomeric properties. We are the market leader in seals for RGD environments. FR58/90 grade is qualified to the stringent Norsok M-710 standard for RGD resistance and sour gas (H2S) ageing.
FR64/70 & 80: Dipolymer-based compounds developed to offer enhanced performance in steam, hot water and mineral acids.
LR5853: Tetrapolymer-based range with hardnesses of 80, 90 and 98 IRHD. These have enhanced fluid resistance, especially with methanol and gasoline-alcohol blends that adversely affect other fluoroelastomers. They will stiffen at below -5°C, thus LR6316 and FR25 are recommended for low temperature use.
LR6316: Available in hardnesses of 75 and 90 IRHD, these compounds are based on a special tetrapolymer with a similar fluid resistance to LR5853, plus improved low temperature characteristics for services down to -28°C.
FR25: Tetrapolymer-based range with hardnesses of 70-90 IRHD. It offers fluid resistance approaching that of the FR10 range plus improved low temperature characteristics for service down to -33°C. FR25/90 is compounded for rapid gas decompression (RGD) resistance in oilfield applications, and is qualified to the stringent Norsok M-710 standard for RGD resistance and sour gas (H2S) ageing.
Chemical properties
