Re: woodruff key keeps dropping...
Posted: Sat Aug 08, 2009 10:55 pm
cezeta wrote:sean brady scooters wrote:is the woodruff key just too big...........?
sounds like its binding on the key which is pushing it to one side.....but then he is spanish so you cant rule out anything....they chase bulls about![]()
try fitting the flywheel with no key and kick it over. if it spins streight then the key is possibly too big.
1-I will try give it a kick without the flywheel to see if that is ok and I get no "clonk" sound. The engine has had an overhawl 500 miles ago, and it has been trouble free. I doubt the flywheel got out of line, since it was trued and the pin and bearing got replaced.
2-I will try stick it without the woodruff key.
3-I have a new woodruff key so if it is ok without it, then I will try the new woodruff key.
P.S: We chase the bulls out, but still, we manage to cook good tortilla de patatas
