Page 2 of 2
Re: welding transfers
Posted: Tue Aug 04, 2009 11:20 pm
by carlos fandango
Thanks for the replies chaps
It was welded by a professional welder and it was pre heated so it should be ok
It was a free, knackered casing anyway, the barrel studs had been helicoiled (not very well) and the welding was a favour
so no problems if its no good
I`ll let you know how i get on.
Posted: Tue Aug 04, 2009 11:22 pm
by J1MS
I think the welding looks well done... and if its been properly pre heated I would think it should be fine...
Posted: Thu Feb 11, 2010 1:30 am
by Yanker
I've had a couple done now too: Not stud conversions, just extra material (for R250 + a 3rd. case transfer)
I always leave in the max to help against distortion: Mag where possible, mag studs + bolts, driver bearing, cylinder studs(not poss here I know). Convinced it helps. The pictured case will need a good amount removed again to fit the Mag Housing.
I am convinced thare are good gains from the effort involved...as Alan Diablo says
Posted: Thu Feb 11, 2010 11:50 am
by vince
Diablo wrote:Someone who knows what they are talking about regards welding may well tell me I'm talking out of me arse
If you dont drop your trousers whilst talking out of your arse it will sound like you are mummbled
But what your rings true.
