Page 2 of 3
Re: Stuttering & four stroking
Posted: Fri Jun 26, 2020 12:03 pm
by Lambretta67
How come the hot weather doesn't affect my p200
Posted: Fri Jun 26, 2020 1:37 pm
by coaster
Lambretta67 wrote: ↑Fri Jun 26, 2020 12:03 pm How come the hot weather doesn't affect my p200
Quirk of the engines setup Id say, changes in altitude will affect the air fuel ration too.
Posted: Fri Jun 26, 2020 4:14 pm
by Lambretta67
How can I stop it doing it.
Posted: Fri Jun 26, 2020 8:11 pm
by MightyGem
Could someone explain "four stroking" for me please. Never sure of what it means.
Posted: Fri Jun 26, 2020 8:46 pm
by Lambretta67
I used the expression to mean the scoot was stuttering & running a bit erratically but it probably doesn't mean that. Sounds good though. Makes me sound like I know what I'm on about.
Posted: Sat Jun 27, 2020 9:20 am
by hat
Could be his engine is marginal in ideal conditions, so any change like the hot weather immediately makes a difference. Or it could well be worn carb components
4 stroking generally means its over rich and the engine sounds like its making 2 beats for each engine turn rather than 1, making it sound harsh and rough. It usually smooths out with more revs and in higher gears
Posted: Sat Jun 27, 2020 9:55 am
by Lambretta67
Exactly what the scoot is doing
Posted: Sat Jun 27, 2020 12:46 pm
by coaster
4 stroking usually occurs when you back the throttle off slightly and it sounds like a machine gun. Its actually firing every other stroke like a 4 stroke motor hence the term.
Posted: Sat Jun 27, 2020 2:54 pm
by Lambretta67
I might be being a thick but what does marginal in ideal conditions mean & how do I sort it. Cheers
Posted: Sat Jun 27, 2020 4:24 pm
by Daggs
Some years ago I built an Imola kitted scooter. In the Winter it flew along happily. But when hot Summer days arrived it would splutter in mid-range. I spent time changing the Atomiser and needle position (several times) until it just stopped spluttering in Summer. I found the next Winter, it still ran O/K.
