Re: engine dies.
Posted: Fri Mar 13, 2020 12:30 pm
any solution on this issue ? i had exactly the same issue which turned out to be a sticking float pivot. The float pivot had swelled slightly between the pivot posts and jammed therfore the float needle valve was stuck in the closed position The carb would run for about 30 seconds until the fuel in the fuel bowl ran out then cut out. Check the float swings freely and the float valve operates as it should[youtube]https://youtu.be/AhkMb2kvxOc[/youtube]
